04.22.2007 at 10:29AM PDT, ID: 22526607
Reduce fan noise from HP DL380 using support pack
Asked by roy_batty in Computer Fans and Cooling, Miscellaneous Hardware, Microsoft Server
Tags: , , ,
I have recently bought a second hand HP DL380 G2. When I first bought the machine it had Mandriva on it.
When it first boots the machine is quite noisy due to the many fans onboard. After the OS had booted the fans settled down so that the noise dropped off considerably.
I have now installed MS SBS 2003 onto the device. After booting the fan noise continues at the same level. There is no drop off in fan noise. After searching around I have heard that installing the Proliant support pack would give me something called cpqhealth which would reduce the fan noise.
I am struggling a bit with this, can someone help me. I have downloaded the latest support pack, but cannot find anything called cpqhealth.
Any help would be appreciated. My neighbours would also be grateful, as the server is in the garage at the bottom of the garden and it is them that it is likely to upset!! :)
[+][-]04.22.2007 at 07:06PM PDT, ID: 18955886
[+][-]04.23.2007 at 12:58AM PDT, ID: 18956724
[+][-]04.23.2007 at 10:30AM PDT, ID: 18960054
Zones: Computer Fans and Cooling, Miscellaneous Hardware, Microsoft Server
Tags: fan, dl380, noise, hp
Solution Provided By: andyalder
Participating Experts: 3
[+][-]04.25.2007 at 11:08AM PDT, ID: 18975880
20080716-EE-VQP-32
