When I bring mt toshiba satillite laptop out of hibernation the fan stays at high speed. I have found what I think might work but havew no idea how to implement the fix. Anybody help me implem...
I'm trying to learn how to use Speedfan.
I have used UGuru to change fan speeds but UGuru does not seem to change the CPU fan speed anymore. I keep trying to lower the speed as the core temp...
Hi - I need a "how to" - pull apart LG notebook to install CPU fan - any help would be appreciated.
My server room spent at least 24 hours at 120 degrees plus. The smell of burnt electronics still looms 24 hours after repair.
All systems came back on and are currently running but some st...
Hello experts,
I have a system that reports that the processor fan is not working and turns itself off after 5 seconds. I installed a new fan which also would not run when plugged into main...
I need to compare (Pros & Cons) of liquid cooled systems. Are liquid cooling systems worth the hassle? Anyone have both sides of the story???
I have a dell XPS Gen 3 and in the bios settings there is nowhere that i can see to disable the fan monitoring. I replaced the rear fan and cpu fan and now it pauses to alert me every time i ...
The backup fan for my Dell Server died on me. I went onto Ebay and purchased a replacement (Dell wanted $120 for one) but upon arrival it is not quite the same. The fan that died was...
I have an ASUS A8N-SLI Deluxe motherboard that has been working fine for about 1.5 years. Today, when I came into my office my PC had shut down during the night and when I tried to reboot, it...
I have an ASUS A7J laptop. It was shipped with an Intel Core Duo processor running at 1.66 GHz, model # T2300. I've upgraded the processor to a T2600 and now my CPU runs very hot. It will i...
Are my Laptop P4 3.0 Ghz CPU Temperatures too High.
We are dealing with a IBM G40 Laptop that had a new motherboard installed by a non-professional. I may have done a fine job of installing...
i have a 320mm side case fan, yeah i know its a beast and covers almost the entire side casing. i thought it was a cool case, and it does a great job. anyways, the leds on it are pretty annoyi...
I have an HP Compaq xw3100 workstation, see it at:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?locale=en_US&prodTypeId=12454&prodSeriesId=346790
OS: XP Professional
Eve...
I am working on a clients desktop that is having some heat issues. The customer was stating that it would often freeze and shutdown on its own. I installed MBM5 to monitor the heat. The highes...
hi I ran a program called Speed Fan on an hp desktop computer and all the readings looked ok except for the Core Temperature.It was reading 60c with a little fire icon next to it probably sign...
I have a Dell Dimension 8400 that has shut itself down a few times. When starting back up I get a message saying the system was shutdown due to a heat event hit F1 to continue. My power supply...
I'm looking for software that I could use to monitor temperature on servers. I would like to find something where I could have a widget of some kind on my desktop to monitor several serve...
i might be getting a dual core allendale intel processors which run at 2.2 each. i want to overclock them to at least 2.6 if possible. will i be okay with the cpu fan that comes with the proc...
Good Afternoon,
I have spoken with support for the motherboard and Intel...neither of which say there's a problem. My processor keeps going to 100% and the fan speed goes up to 4000RPM...ev...
THE COMPUTER SHUTS DOWN (INSTANT POWER OFF) AFTER 3-5 MINUTES.
BOTH THE PROCESSOR AND THE CASE FAN SPIN BUT NOT AT START UP, ONLY FOR A VERY SHORT WHILE AFTER RUNNING, THEN THEY STOP. I USED ...
CPU fan stuffed so I replaced it with generic cpu fan. Would not operate. Switched fan into another plug. Fan works ok. But system now closing within 15 secs because cannot detect cpu fan. How...
My ECS PF5 Extreme motherboard's chipset fan has developed a really annoying squeal. I guess the easiest way to correct it is to disconnect it. Has anyone else done this? Am I going to ...
I took in a customer's Compaq Presario 900 laptop today with a bad DC Jack. I disassembled the unit with no problems what-so-ever. I replaced the DC Jack and now when I power up the unit (does...
Ok so my toshiba laptop cooling fans start when I turn it on but right away they stop spining and as soon s the computer / CPU gets to hot of course it shuts down.... Please help I've seen thi...
