Top Power Supplies / UPS Solutions: 1 - 25 of 62
Hi, I'm trying to use PowerChute Network Shutdown to shut down running VM's and power off the host in the event of a power failure. I'm using ESX 3.5U2 and PowerChute Network Shutdown pcns-...
I disconnected my PC to rearrange my computer room. After reconnecting, computer will not power up. There is a green light behind the power supply and it blinks. Even when I unplug the power c...
We have an APC SMART-UPS 1000 battery backup that gives a "discharged battery" and "Insufficient runtime available" error.  We bought new batteries for it and replaced them.  After the new bat...
The machine will not power on, there are no beeps, no power to the fan in the power supply or in the case when the power button is pressed. I jumpered the power supply and the fan for the p...
I have a Dell XPS600 that shut down out of the blue and will not power back up.  The power LED blinks yellow.  No noise at all is heard when trying to power up (eg no fan noise, or hard drive ...
This seems to be a very strange problem and it has been going on for sometime, I would not be surprised if the problem is the wiring in my home because I live in a college town where the homes...
Hello, My APC RS1000 has an internal fault and needs to be replaced. What I am curious about is how Belkin and CyberPower compare to APC. Interestingly enough, it appears that my APC only sup...
I have Dell Dimesion 5100 which one day stopped turning on. To troubleshoot the issue I have tried quite a few things such as disconnecting all extra cards, memory etc without any difference. ...
My computer shows low battery at 6%. Will work when plugged in but it will not charge the battery, which remains at 6%, does not increase or decrease its charge. I can use it when plugged with...
This Gateway model has a power supply that I have not been able to match against the various form factors I know of.  It does not match the various standard form factors I know of including AT...
Dell Dimension 4700 NO video, no discernable beeps Front amber light steady Fan runs high Cleared CMOS Removed, reinstalled memory, left it out, tried a new module checked electrical c...
In this case, the same power supply that came with the computer now generates an error at bootup stating the AC adpater cannot be determined.  Press F1 to continue or Press F2 to not display t...
My abit motherboard requires an ATX 24 Pin Power Connector and an ATX 12V 4-Pin Power Connector (CPU Power). I have an Ultra 600 Watt ATX Power Supply Model # ULT-XF600 witch has a 24 Pin Powe...
I have some expensive servers that process very large log files. These are not typical servers with attached users or critical data - these servers are just dumb processing engines. Each of th...
I like to protect a few servers in my network. I found a surge protector M4T-EX (called SP) from Panamax  which comes with 4 power outlets and 2 LAN ports (one goes in and the other comes out)...
We are a company in Houston without power. We have a generator for building power. Has anyone any experience with running on a generator that the PC's (or building) would require an inverter. ...
Does anyone know where I can find a TGR FM-180PIO Switching power supply?  I need to find a replacement and haven't been able to find exactly the one I'm looking for.
we have HP DL 380G5 server and we have received alert that "System Information Agent: Health: The fault Tolerant Power Supply sub-system is in a failed state. Restore power or replace the fail...
Daughter has Dell Laptop, approx 3 yrs old.  uses  -- school and social Was receiving error message that adpater cord was invalid, (Error Code 3600:0649 Msg: invalid AC adapter reported). In...
Let me know if there is a way to give power to a PC without having to attack it to the electricity,some kind of system battery (little and inexpensive) to kept powered a system for a couple of...
I have a customer who reported no power to their 2 year old HP pavillion a5040a desktop PC. I installed a new PSU, and the machine started fine and booted up to Vista The only problem was th...
My UPS no longer turns on. I have tried multiple wall outlets and I have tried the reset button on the back. If the problem was the battery, would there be some indication of that? I get no li...
Hello, A bit earlier my second computer powered off on it's own, and it's not turning back on Right before it shut down we smelled like something "overheating" (sorry english is not my f...
I had a message come up on a laptop (Dell Latitude D810) saying something along the lines of "Your battery is coming to the end of its life". So I got a new one. The new battery will not w...
Hi Folks I live in the UK I was wondering if it is safe to put a UPS in the roofspace of my bungalow? I would like it to provide power to my computers downstairs but also provide power...
