Ive seen this error on two different laptop connecting wirelessly in different locations
Each were in separate buildings (different routers / networks)
Each were in workgroups.
I want to set up wep key for my wireless so no one can use wireless except me..
When I type the key in the box the message says "Invalid WEP Key 0 ..."
What do I have to type?
We are having crasy issues with our wireless cards in our Dells. It seems to be just the d630. When ever a user tries to connect the any access point (here or at home) they get a 169 address. ...
A friend has a PC running Windows Vista Home Premium - the internet connection is via a 3G USB modem which works fine.
Her family are coming to stay for vacation so she wanted them to be ab...
I have a Dell Inspiron 6400 laptop, running XP SP3. The laptop has an internal wireless card, a Dell 1390 WLAN mini-card, which I use to connect to both my home and office networks.
Until r...
I installed driver for Broadcom 4322AG (HP Compaq 6735b laptop), it looks to work okay but it doesnt see any wireless network. Driver version is 4.170.77.3. I tried to install also HP's wirele...
My boss tried connecting a printer to the wireless network at his home (it works when an ethernet cable is connected to it), but got an error message saying "MAC address filtering may be enabl...
I am trying to update the wireless driver. The update works successfully, but after the reboot, I am not able to connect to my wireless LAN. The ThinkVantage Access Connection failson "Waitin...
My laptop uses D-link Air DWL-650 wireless network adapter. Os win xp sp3.
I've configured my wireless router to use wpa2-psk, but unable to find that option on the laptop when configuring th...
I have a dell inspiron e1405 and I have the wireless card Dell Wireless 1390 WLAN. I would like to use the microsoft wireless manager but my wireless card will not connect if I try to manage t...
When I try to connect to Internet via my friend's wireless, I get the "connected" icon and then the "limited or no connectivity" error message and cannot access the Internet.
I have a Linksys network in my home office, it consist of four computers. All of the computers are running Windows EX Pro w/SP2; all of them have IE/7 and Mozilla/Firefox browsers. The serve...
Hi, I have a linksys AP WAP54G, I conneted it to a motorola cable modem, I want to know the AP IP address, I configured it with DHCP and the AP works perfectly, I can browse the internet with ...
Hi Experts,
I have been banging my head on a wall of late.. I built my own gaming machine, and it works a beaut running Vista 64 Ulitamate.
I was using a 10m Ethernet Cabel to connected m...
Does any one have a suggestion as to a long range Wireless PCI Network Adater (g). I will have to use and external antenna. The wireless PCI adapter card must have great transmitt and recieve...
Unable to enter a 128-Bit WEP Key ... keep getting "Invalid WEP Key
Hi Everyone;
I have a Microsoft Wireless USB Network Adapter, 802.11b series (Model MN-510) which never detects a signal from the Microsoft Wireless Router, series 802.11b (Model ...
I have a couple of WAP54g's and a WRT54G not in use anymore. I have a computer out in my shop that I need a wireless adapter on.
I am wondering if I can use one of these units and the cat ...
My wireless connection goes in and out on my laptop for no apparent reason. The laptiop is physically conneced to the router and I can still connect to tne internet. However, for no apparent...
I have a laptop that says the wireless network connection is connected and signal strength is excellent. I have a legitimate IP address of 192.168.10.5 on a wireless LAN 192.168.10.1 / 255.25...
Just installed 29 Cisco 1242 devices. From hardlines I can ping any device on any AP. From a wireless device, I can ping any device not on the same AP. What stops the pinging on the same AP?
I have a Linksys VOip connected to a ADSL modem wihich then access the internet.
Linksys VOIp has a static IP of 192.168.0.1 with DHCP enabled.
PC connects to Linksys voip adapt...
I have installed CentOs 5.0. In the installation. i see a Wireless Card Broadcom, but i can use it. I dont know if it's right configured and if it's needed to know much for make the installati...
I have a Windows 2000 computer that sees the network using a wireless nic. When I first set this comptuer up, it was wired using an ethernet connection. After I moved it from a wired connect...
I have a wireless at home; anytime i set the encrytion to WPA2, my Sony Vaio is unable to connect to the wireless. It's ony able to connect to it after i reset it to WPA. this is baffling, any...
