Time Tested Network Design & Methodology Solutions: 1 - 25 of 195
Cisco 3560 and Vlans (500 points up for grabs here) we have 2 cisco 3560 switches connected together via fibre using a sfp module runnung as a 802.1q trunk. I have set up 3 vlans on both swit...
Can some one help me to create this in Packet Tracer Ver. 4.11 files and document? 1) Containing basic network (without ACLs) files. 2) Containing the network with ACLs applied files. 3)...
Hi We two core switches when i try to create new Vlan 1172 in core 2 i am getting "% Failed to create VLANs 1172 Spanning-tree extend system-id need to be enabled." when i checked ...
Hello, I working in an environment that has its own seperate network. The network consists of several Cisco 3750 switches. The network also has some devices on it that send out Multicast traff...
We are working on setting up a Voip phone system and I am looking at setting up VLAN's on our switches to allow for a tagged vlan for our voice network. Here is what we have: Core switch HP...
I'm completely new to VLANs, but what I've read about them is very interesting, and will potentially be a significant increase in our security.  Unfortunately, I'm pretty sure I'm only getting...
What is the difference in using straight through cable and crossover cable in connecting a switch? I have read some books that to connect a two switch together you have to use crossover cab...
We have a schoolwide network with over 700 computers in multiple buildings.  We have a gigabit fiber backbone and appromiately 60 Cisco 3500XL switches and a 6500 series core switch tying it t...
Hello All, I have a cisco 2950 series catalyst switch.  I setup port fa0/23 - 24 to be an ether-channel and a trunk, with the ether-channel being named Port-channel1. I want to configure...
Hi Experts, I'm setting up a new branch office very similar to the one shown in the attached diagram, and wanted to run it by you guys before buying any equipment. My two questions are:...
Where can I find a stencil set (.vss file) for Visio 2007 containing all the basic non-model-specific Cisco symbols?
Okay so we're looking at possibly making our network uber-redundant.  I've been asked to piece together possibilities/costs associated with having dual routers, dual firewalls, switches, etc, ...
I am a complete newb when it comes to VLANs, unfortunately the documentation that came with the Dell switches I have hasn't really helped my learning curve. I have six Dell PowerConnect 2716's...
http://www.alliedtelesyneurope.com/site/files/supportdocs/at1086   This is the link to the install guide for a Centrecom FS708.  My en1 connects to a gigabit auto md1-mdi-x 8 port switch with ...
Hello, I'm new to the whole MPLS Setup. I'm trying to connect remote sides using BGP on the providers side and EIGRP on our side. I'm able to ping router from router on each side trough MPLS ...
http://www.experts-exchange.com/Networking/Network_Management/Network_Design_and_Methodology/Q_23257886.html This question is a small continuation of the above completed thread. If I do every...
There exist several WAN acceleration devices, like Riverbed Steelhead appliances, that reduce WAN traffic through various compression and data reduction techniques. These devices all have in...
Hi Experts, I got a Cisco ASA 5510 with AIP SSM 10. I'm new to this device and wanted to deploy it as shown in the diagram. I have two Internet DSL lines (dynamic IP) and those connection a...
is it possible to do port teaming on cisco switches. The idea is to use two ports of a 10/100 cisco switch to link a 1000Mbps cisco switch by using port teaming. This because the 10/100 switch...
Hello Experts, My network:3  - Microsoft Server 2k3 sp2 (both)  - 2 domain contollers - 1 of them is exchange  - both run dns  - symantec Enterprise I recently created a GPO that wou...
Experts, We have an HP ProCurve 5412 swtich and 3 Cisco 2800 routers.  We also have a main branch which needs to supply non-employees internet access from time to time.  Our main brach is o...
Hello: I have a brand new 2851 router.  I have assigned an IP address to the GE0/1 interface.  I have connected that interface to my switch that also connects to my laptop.  This is to make s...
im having an issue with scan router it can only save locally. it can not be on a DC or anything with SQL and does not save to a mapped drive. the files it needs to get to is on the server. no...
I`ve just started to work with Nortel switches. Have always been working with cisco. When I created a new vlan on a cisco router I created a vlan and assigned a ip address and mask. With norte...
I need to create a route across the LAN between two Linksys Routers.  An RV016 (LAN1) and an RV082 (LAN2).   The LAN Segments are: 1. 192.168.81.0/255.255.255.0 and; 2. 126.169.71.0/255.255...
