Time Tested AS400 Programming Solutions: 1 - 25 of 637
Hi i am asking behalf of my friend. What is the ascii code for the carriage return in AS400? charachter=13??? or ?? i dont know what exact thing my friend looking for...but sort o...
Hi all, I have a quick question about the syntax for an SQL statement I am writing.  I need to know how to do an UPDATE statement such as: UPDATE U269672.MYFILE SET [Date Created] = .....(...
I am trying to create a stored procedure using SQL/400.  I need to compare a date that I have converted to a character using the character function: CHAR(YEST2,ISO) (character version of yeste...
Hi Where an I download AS400 OLE or ODBC driver for doing development work for VB to connect to AS400. Is the OLE ODBC Driver suitable for all kind of AS400 server/client connection ? ...
In Free Format any ideas on how to Convert a Date text string to CCYYMMDD Decimal Eg 'March 2006' -> 20060301 Lenght of date varies depending on Month Value Eg 'August 2007' -> 20070801 ...
I have a spool file from the as400 when it is copied to a physical file for pc manipulation, it loses it format. How can I get the spool file to the pc without losing the format. I will post a...
   I've just got a job on AS/400 RPG Programming. Actually all my experiences go through SQL Server, And Windows Base Programming. So I wonder...     If there is any AS/400 Simulator for win...
Hi, Simple follow-up question. If i take the decimal number 98 and pack it into 1 byte i understand that: 9 becomes the firstpart of the byte (1st nibble) 8 becomes the second part of ...
Is there a simple way to call an AS400 (RPG or CL) program from a C# program?  I would simply like to call program, pass parameters, get return values.  I am using OLEDB to access the AS400 da...
Hi I have to format date to the iso 8601 format. I'm using AS400 who returns the date to the format "yyyy-MM-dd" and time as "hh:mm:ss". How can I in VB or C++ get my date as the ISO 8601 f...
I'm studying about AS/400 System. Comparing to Windows, it's hard to find some information about AS/400 on Internet. Although I've some documents from IBM site, it's also difficult to unders...
Hi all I need some step by step guidance on this one. I have got to the stage where I see the iseries add on in Excel. Could someone please give me some instructions how to transfer ...
Hi Guys, I am trying to get IBM Client Access V5R2 5250 to work via the internet using VPN. I have configured the VPN Appliance to allow the following IBM Client Access Ports through to my ...
As of Now, I am using CPYTOIMPF to first get .csv format file from AS400 physical file and then I am using CPYTOPCD to convert it to document (which will be in csv format). I am mailing this c...
Anbody doing SQL in a CL on the Iseres? thanks in advance, Don
How can I declare RPGLE array Data structure?                                               How can I use in side the RPG PGM?           TIA-MW
Hello: I am working for a company that has an international country (Turkey) setup on the 400;  It  has specical code-page-settings on the file at the field level (JDE F0101) (code page 37) s...
I have a program which gathers user information weekly for 3 companies.  2 of these companies reside on the same iSeries AS400 (v5r3) in 2 different libraries.  The 3rd company is on a remote ...
          I've just got a job of programming RPG langauge on AS/400 platform. What is the most obstacle I've from getting my job is that I cannot pratice RPG programming on standalone PC. Sin...
Using a CL program, I want to pull a packed date field from a file and pass the date as 3 fields; &MM, &DD, &YYYY to another CL program.  I am able to get the date field from the file, but am ...
Is there an easy way to create a timestamp field from a date and a time field? I'm currently converting both the date and time fields to character using %char and then appending them together...
Hi All Got an interview for an ERP company where I'd be based at a large client.  It's a desktop/lotus notes/as400  Now the windows and notes part will be a walk for me.  But I haven't work...
All, In advance, thank you to anyone who can help me out. I am attempting to create a "cdp" file (Connect:Direct process) that will transfer a log file from an NT server to an AS400 serv...
OK, My eyes are getting tired from reading through EE.  It's very informative with suggestions but I need a step by step to connect to our AS400.   I did get the DATA Menu>"Get External Data ...
Big points for this, so ya gotta do some thinking!! I want 30 questions that would most likely come up in an interview that programmers and managers ask potential new RPG programming employ...
