I would like an explanation on how to make an intro in Action script 3. I work well in 2, but I am completely lost in 3.
I want to have the following:
10 movie clips - 1 on frame, 1 on ...
I am working on my website and have incorporated a dynamic horizontal menu at the top and one of the menu has sub-menu's. Just below this menu is an image. Problem is the submenu appears beh...
I have a small animation that runs 300 frames (10 seconds) All I want to do is loop the last 2 secs so in flash I would do a gotoAndPlay (240) on the last frame. How can I achieve thi...
Hi Experts,
I have the attached logo. How can I make those waves move? Like from the small to the big wave. It should look like sending signals.
I'm new to swish :)
Thanks in advance,
I am looking for a way (or Flash component) that will reorder image thumbnails and write the result to XML
Hello Experts,
I require some tips. I have a simple HTML form that has 5 drop-downs (selects). These variables are measurements that define an "L-Shape".
What I require is a small "Flash...
I routinely need to create entity-relationship diagrams or flow charts. It nothing elaborate - just outline shape containing text and connecting lines. The lines need to have various endpoin...
FLASH - I have 2 characters on the stage dancing to music. I have it timed out so that the frames match nicely in the "test Movie" mode as well as in iternet explorer 7 and even in Safari for ...
We are looking for a web-based charting package (mainly XY line and scatter plots where the X values are dates). Requirements are for the users to be able to save and download the generated pl...
i hope i've got this question in the correct zone.
i have a site with png files. i am creating trans gif files for MSIE. at this point all i've done is loaded
a test page with the gif file...
I converted a table from Word to Kompozer and the first top cell on the left has a different border than the other cells. I cannot figure out what is wrong. I want the border to be the same ...
I have just insert a SWF movie in my webpage...
http://www.mytesting.co.uk/Mar/index1.php
Which is fine in IE, but just a blue square in Firefox, can anyone help?
Although when I pas...
Hello Colorists!
Thanks for reading this question! If I have found a really pretty pastel green. Is there a way to convert it to a corresponding pastel blue? Some kind of formula to re-w...
Hello !
I found a very good script : http://www.flash-game-design.com/flash-tutorials/triple-scroll-gallery.html with the actionscript code and "triple-scroll.fla" here : http://www.flash-gam...
Hello, I created a photo album in DreamWeaver/Frireworks and my question is how to resize the photo so it displays all in one screen. Please take a look at my web page (link below), the fir...
Hi guys: Can any one please help me from where i can get the icons of the following?
1.About Us
2.Where we located
3.What we treat
4.Links
5.Medical Deseases
6.Our Staff
Thanks.
This is an off the cuff site with dropdown from the top. I am creating drop down coming out from the right with the ability to click to a different page....http://cohenbattisti.com/orlando-cri...
Hi there, I am trying to make a web graphic to put into my website and the text in the browser is difficult to read and doesnt look quite right.
I have tried to sharpen, save as a gig, jpg ...
I'm looking for raster to vector conversion software... it doesn't have to be expensive, I'm only playing around with .bmp and other images. I can Google for them, but perhaps someone has...
How do I set or change the border width when I draw a shape in Photoshop?
Please give me your thoughts/criticisms/suggestions on this website:
http://tinyurl.com/5s6h33
Specifically the design, layout, navigability, and functionality.
Please list criticism,...
