I'm trying to load external swf file to main swf to center the browser window. There are buttons to call different swf to load into the same box, called holder. There are extra codes...
Hello!
I have built a Flash file which has some buttons and a scrollpane. When you click on a button, a movie clip loads in the scrollpane. Everything works great. My issue is that when ...
I'm creating a map where users can rollover icons in the legend to highlight areas of the map; conversely, they can rollover areas of the map to highlight the associated icons in the legend. F...
Is it possible, when using FileReference, to separate onSelect into 2 buttons. Browse and Upload?
Now, as soon as you select the local file Flash starts the upload.
What I need is to bro...
With FLV files, it is relatively easy to import them into flash, make a video component that can play/pause/stop/scrub the FLV, and then make a SWF file for use in an HTML file on the web. Bu...
Experts, I need some help fading a movie clip using action script 3.0. I have seen various tutorials regarding this in concept, but I can't seem to find anything conclusive.
I have 7 movie...
Hi, I have 2 different sounds in flash actionscript 2.
They both paly simultaneously.
I need to be able to set sound1's volume for instance at 20% while sound2'1 volume will be set to 80%....
is there any way of telling if the v scroll bar is visible in a text area, i know about getViewMetrics() which returns a object with width of the borders, ie if scoll bar is visible right widt...
Hi all,
I want to stream/play Vorbis OGG files in a web browser using Flash. As far as I understand, flash plays mp3s (and maybe wavs?) but not OGG files. Anyone know a way around this?
Quick question: How do I take the dynamic variables on my page, and load them into a Flash Player (SWFObject)?
Now, the long version with all the details of what I'm trying to do:
The ...
Looking for an easy to use, good quality Flash /swf + flv) downloader, thinking of a right-click solution which extracts all files/container to a defined local storage.
right i've attached a few files....
firstly, the test.fla contains the vertical scroller that runs off 4 preloaded images.
the second file contains a slideshow, that loads from the image...
I've been trying to insert a combo box inside a datagrid using Actionscript 3. Found examples for Actionscript 2, but all my code is in AS3. I've tried way to many verisions that don't work ...
Hi, i am having a flash presentation to be made and i am given a swf file that has to be included in one of he slide. i have been able to load the swf file from the required slide in flash fil...
Any embedded videos played either in Firefox or IE appear silent. No sound at all. My computer is an Acer 3680 notebook with 1.5 gigs of memory. Windows XP Home. Every other application plays ...
Hello
I want to be able to measure the page flipping behavior of my users. The flash flip book on this page allows users to flip through the book but I have no way of knowing how may pages...
I have a flash swf module I need to put in my webpage. It was given to my by someone else. So changing the flash source isn't exactly easy.
I want to scale it down so the width of this f...
I have a working slideshow that currently uses manually-created image movieclips which reside in the symbol library. For these, I use attachMovie so that I can use them as slides in the slides...
Experts,
I'm completely new to Flash. I have a flash video that I want to add to the website I'm working on. I would like to add some functionality to the video. On several websites I've...
Hi! I need to develop a flash client for sip protocol, but i don't know where to start :-(
Is there any libraries, or script example or tutorial to follow?
Any clues?
Thanks in advance
I am trying to help a friend setup a website from a Flash template that he has purchased. You can see what we have done so far at http://powell.go-pokes.com. What we want to accomplish is to...
I have a flash form and I am trying to validate the phone field.
If all numbers are not entered then the error will show above the form like the other validations.
Here is the f...
Hello
I am trying to highlight and/or to make a row glow inside a datagrid.
We can call the datagrid X, and the row i need to highlight is the 5th.
So in essence i want to do something li...
I am trying to export a flash file as an animated gif. (client cannot use swf files)
But the text that "fades" in and out now only appears as a white box.
How can I get the animated gif t...
There are many good videos in different formats on image bank iStockphoto.
I plan to use some of them for banners.
So my question is how to reduce the size (width, height) to get a good qual...
