I have installed WebSphere 6.1 and then installed the fix pack 6.1.0.17 on that. Now when I am trying to install web server plugin for WebSphere, it fail before it start with the below error i...
I am trying to set the domain controller which contains the PDC Emulator in my domain to gain its time source from an outside source.
If I wanted to have the server gain the time source f...
When i try to connect to FSRM i have the following error:
Unable to connect to the file server resource manager service on computer \\grkfs1. The file Server Resource manager service is not...
Hi experts, i just started deal with debian eth server , connecting it with putty and have some questions about it ;
1) How can i create FTP User ?
2) Found some 3hd party tools to man...
Hello Experts,
I have a Web Portal (www.myportal.com) and i also have a video aplication (videoapp.myportal.com).
When anyone type www.myportal.com.br/video i need to redirect the reques...
When I try to login into Mercury Quality center it was hanging and it was not allowing me to proceed further. I can able to login into another's profile but not in my profile.
I tried by re...
I have a dedicated server. I am using plesk 8.3.0 I am very new to this. Now my need is to create an ftp account for myself so I can upload the files after I finish working on them on my local...
Recently installed a godaddy ssl certificate. It's working fine in FF and IE, but in Safari we get the error "Safari can't verify the identity of the website ... ". After clicking continue and...
I've googled and contacted every moodle dev tech that I could and I still have no answer to my problem...
Here is my error in moodle:
unicode must be installed and enabled
It is requ...
On a Windows XP SP2 sony vaio laptop witih DSL modem and linksys WRT54G router, we connect to the internet fine for all websites, except:
We can't can't connect to:
www.lulu.com
with ping...
I'm in the process of ordering a dedicated server and not sure which OS to go with out of Ubuntu or CentOS?
I've been having problems finding the right syntax to exclude a string using regex
I'm trying to create two RewriteRules ..
For example
1) I have one URL type that is /search/page1/ tha...
i have a NEW site that will be in a temporary folder /new, but all the references to css-files and javascript-files are absolute from the root.
Example
<link rel="stylesheet" type="text/css...
I have a dedicated server. I use cPanel / Web Host Manager to administer it. cPanel is sending me scores of notices headed "Massive Amount of Failures from IP". The body of the message states ...
I just installed a server running CentOS 5.2 and plan on using it as a web server. I need to enable DNS and have app.testcomp.com point to //10.10.10.158//var/www/html. Clients will get thei...
Using IIS 6 in Win2K3 server. There are about 5 sites configured. After some time, whenever we access any site configured on the server, we get error "Service Unavailable". This happens for al...
Hi experts, i tried to install webmin but not sure if i did it correctly , how may i ensure that its working or not blocked by a firewall ?
Basically this error is telling me there is nothing found at this location... there is a folder there for sure.
Does anybody know if there is anyway to mess up the htdocs/ folder locally....
I'm getting an error like that when i starting my application :
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (JZ006: Caught IOException: java.net.Con...
whar are Contents of WAR , JAR and EAR files>
difference between these?
Currently i have 2 website projects and i need to know how to determine the webserver spec/requirement to buy.
project 1 - Video sharing, just like youtube (assumption of 100,000 visit...
We have a web based application that we used in our organization. Our set up consists of an Internal and external access.
We are using II 6.0. We currently have 2 different web si...
i would to stop people from downloading video from my website i have already changed config.inc.php but sofware like Orbit Downloader i ruining my exlusivity . do you know what need to be done...
Hello Experts,
I have some artwork which I wanted to upload it in on the web server quickly. The file size is around 1.5 GB. If I use conventional FTP clients the estimated time its showing...
I'm looking for a website that will allow us to test if our internal network/server could
access Internet via specific ports (in particular Tcp port 8080 is what we're trying to
estab...
